Activity › Forums › Sony Cameras › Extreme Lighting Conditions
Randy Strome
March 30, 2008 at 6:29 pmWe are using pretty similar settings, with the exceptions of detail (I would suggest off, as you can selectively fine tune this better in post if needed) and I have set black to -4 (which sets the curve to map a scene black to 0 IRE). Black can alwas bee deepened with levels in post. You may want to set up a few PP’s based on these setting at a variety of Gamma settings (0, -3, -5, etc).
I have also been using those color settings (credit due to Bill Ravens).
Randy Strome
March 30, 2008 at 7:04 pmEDIT
The above should have read:
You may want to set up a few PP’s based on these setting at a variety of Gamma settings (0, +3, +5, etc).
Randy Strome
March 30, 2008 at 7:06 pm****EDIT****
I had originally written in the gammas above at negative rather than positive values, but actually, I am suggesting that you try positive values such as +5 (which is what my favorite preset for bright high DR scenes is). A postive value in Gamma LOWERS the white point, which is what you are after. A negative value such as the -8 you had found elsewhere will only serve to push your whites further out of range.
Luc Majno
March 30, 2008 at 7:14 pmTHANK YOU Randi for the explanation. What a treat to have ‘experience at the table! 😮
LM -
Don Greening
March 30, 2008 at 8:32 pm[Chris Babbitt] “How much difference?”
I’d like to say about half a stop but I don’t think it’s quite that much. Check it out for yourself though. Toggle between Interlace and progressive mode in the menu and the picture will alternately lighten and darken by a small amount.
– Don
Vladimir Lozinski
June 7, 2008 at 9:49 amGreat suggestions. I will try a few out myself.
Also.
In snow and glare I would recommend a polarizing filter. It deals with the problem before it get into the camera.V.L.
Rafael Amador
June 7, 2008 at 1:32 pmYes beautiful pictures with the PL. But you must be careful. I’ve read that you must avoid any kind of camera movement with the PL.
Mac OX 10.5.2-FC 6.02-QT 7.4.1
G5 2x2Gh 4GbRAM-BlackMagic Extreme
PMBP 17″Core2Duo 4GbRAM-AJA ioHD
JVC DTV-17″
SONY EX-1 . SONY PD170
..and always a big mess on top of the table.
