Activity Forums Apple Final Cut Pro Legacy External FW Drives PAUSE
  • Dndobson
    July 27, 2006 at 6:00 pm
    didn’t work..darn
  • Dndobson
    July 27, 2006 at 6:01 pm
    thanks, if it’s the daisey chaining, that might be the cheapest solution.
  • Dndobson
    July 27, 2006 at 6:03 pm
    I’ll try three, see if that improves things. Thanks.
  • Dean Sensui
    July 27, 2006 at 9:11 pm
    Another possible quick fix:
    Split up your media. Put some of the frequently accessed media on all the drives. That way they’re all busy at frequent intervals and won’t get a chance to sleep.
    Once you get past this problem, consider getting a SATA RAID with hot-swappable drives. They’re fast and, in the long run, cheaper than firewire drives.
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Dndobson
    July 28, 2006 at 7:14 pm
    Thanks – I was thinking the same thing.
    Wondering if a Firewire Hub might help too…
    Ah, SATA…if only. I’ve bought or caused to have bought some 20 of these Segate Firewire/USB Hard drives and it’ll be a while before I can justify swithching them all out.
    I’m wondering also if i need to update the firmware on the drives or get upated drivers for the drives….doubt it, but who knows.
Page 2 of 2
