Activity › Forums › Adobe After Effects Expressions › Expression to delay timing on parented layer
Posted by Pat Bray on April 29, 2010 at 2:29 pmHi there
I wondered if anyone could help with an expression. Basically I have a couple of layers, one parented to the other and want to animate one but have the parented layer to animate say, a second or two behind the other, which will save me copying and pasting a ton of keyframes and have a tidier workflow!
Any ideas would be great,
P
Thomas Anderson replied 5 years, 11 months ago 7 Members · 14 Replies -
Michael Szalapski
April 29, 2010 at 7:05 pmYou will love this.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Dan Ebberts
April 29, 2010 at 7:52 pmIf what you’re trying to do is delay a parented layer’s movement, you could do it with a position expression like this:
delay = .5;
parent.fromWorld(toWorld(anchorPoint,time-delay))Dan
Jamie Bradshaw
November 5, 2014 at 10:03 amThanks for this Dan. I was completely unaware of the fromWorld expression. This is a really powerful technique.
What would be the equivalent expression be for creating a parented delay effect for orientation?
JamieJimJam•Graphics
https://www.jimjamgraphics.com/ -
Fernando Huezo
May 20, 2015 at 9:38 pmHi Dan
Why this expression is disabled when the scale is animate from 100 to 0 on the parent layer? -
Dan Ebberts
May 20, 2015 at 9:53 pmI think those layer space transforms will die when scale is zero. I haven’t tested this, but it might fix it:
delay = .5;
try{
parent.fromWorld(toWorld(anchorPoint,time-delay));
}catch(err){
value;
}Dan
Fernando Huezo
May 20, 2015 at 10:17 pmthe same thing keeps happening
this is my scene I dont know what is the problemI have the HeadKid whit a wiggle in position, the B_Puppet Pin 4 follow the head wiggle with a nice delay, beautiful!!! I animate the scale of the HeadKid 114 to 0 my secod keyframe in scale and boom! thats happen
How fix this problem?
Dan Ebberts
May 20, 2015 at 10:50 pmThe message you posted is actually from a different layer than the one where you have the expression exposed. Did you make that update everywhere you’re using that expression?
Dan
Fernando Huezo
May 20, 2015 at 11:02 pm -
Dan Ebberts
May 20, 2015 at 11:35 pmIf you let the scale go to zero, any expression that has toWorld() needs to be wrapped in try/catch, like the example I gave you.
try{
bonePos = ....}catch(err){
value;
The other thing you could try is not letting scale get all the way to zero. Maybe 0.01 instead.
Dan
Fernando Huezo
May 20, 2015 at 11:55 pmthank you very much for your patience!
works, no more mistakes!many thanks Dan
