Activity Forums Adobe After Effects Expression control – Layer Control
  • Walter Soyka
    June 18, 2015 at 4:05 am
    [Tiago Cav] “Could you teach me how to change for that the expression follow a specific layer, regardless of the index position between the layers within the Comp.”
    This expression already does follow a specific layer. It just uses index as a test — is the index of the chosen layer my index? The index updates as you add, remove or rearrange layers.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Tiago Cav
    June 18, 2015 at 4:10 am
    I want to change the opacity of a layer, every time another layer (“text”) is selected in the “Layer Control”.
  • Walter Soyka
    June 18, 2015 at 4:11 am
    if (thisComp.layer("Control").effect("Layer Control")("Layer").name == "text") 100 else 0
    Walter Soyka
  • Tiago Cav
    June 18, 2015 at 4:18 am
    Very Good!
    Thank you very much!
Page 2 of 2
