Activity › Forums › Avid Media Composer › Express Pro HD and HDV
Posted by Harvey Zinc on May 6, 2005 at 2:03 amWould someone please explain if Express Pro HD is able to process (ingest, edit and export)HDV material. And how this is accomplished using their (to me confusing)DNxHD system.
I’m still not clear if Avid is able to deal with HDV?
HarveyOliver Peters replied 21 years, 4 months ago 6 Members · 14 Replies -
Dom Silverio
May 6, 2005 at 4:26 amNot yet. Feature will be released later this year for free to current Xpress Pro HD owners.
Julie Marzac
May 6, 2005 at 5:58 pmSo how will HDV be handled…natively or with an intermediate codec similar to Cineform Aspect codec?
Julie Marzac
May 6, 2005 at 11:00 pmThis from an Avid press release.
“editors using Avid Xpress Pro HD will be able to simply capture, edit, and output native HDV back to tape.”
This will be a sluggish non realtime solution…no?
Dom Silverio
May 7, 2005 at 3:10 amYou will be allowed to render with DNxHD codec. This should increase performance.
George Costacovich
May 8, 2005 at 10:15 pmdo you know whether the HDV upgrade will enable a decent offline workflow? will it be possible to do frame-accurate batch capture?
George
Dom Silverio
May 9, 2005 at 9:00 pmI don’t know for sure. Specifics have been limited. Batch capture sure be standard. I know some manufacturers are having issues with HDV and batch capture in general, but I think it is imperative for Avid to solve this.
Julie Marzac
May 10, 2005 at 9:02 pmIt is my understanding that Express Pro HD allows capturing DVCPRO HD over firewire as DNX HD. It would seem DNX HD at 220Mbit/sec 10 bit would be the best way to deal with DVCPRO HD, when using multiple graphics layers. Correct? Or is it better to work with native DVCPRO HD? I am a non AVID user looking to switch.
Dom Silverio
May 10, 2005 at 10:35 pmDVC Pro HD captured via firewire remains as DVC Pro HD. The process is exactly like DV.
You can render FX and import material using the DNxHD codec instead of DVC Pro HD. -
George Costacovich
May 10, 2005 at 10:46 pmSo when capturing DVCProHD over firewire in AXP, the only res selectable in the capture tool will DVCProHD? no access to the standard resolutions of 15:1s, DV411, DV420, 1:1 or the DNxHD codecs? will this be the same story when the HDV update for AXP 5 arrives?
Oakmozart
May 11, 2005 at 2:58 amMy understanding is that you will either 1) work with HDV in its native format and all effects will be handled via DNxHD, OR, 2) the HDV will be captured as DNxHD, where you will be able to work with it in RT, then output it back again as native HDV, again with all your effects remaining as DNxHD to allow for RT output over firewire without Mojo.
This is from my reseller. Since no definite specifics have been given (including release date, which I’ve heard will be anywhere from June to October), this is simply speculation. However it’s done, Avid has said straight-up that it will be an elegant solution and the best in the industry. We’ll see.
