Activity › Forums › Apple Final Cut Pro Legacy › Exporting to quicktime
  • Rafael Amador
    April 24, 2009 at 4:53 pm
    [Göran Thorén] “I have also noticed that FCP doesn´t do a very good downconerting jobb”
    I don’t agree with this.
    I would never use FC to up-size nothing, but for down-sizing FC makes a VERY, VERY good job. Comparable to Compressor.
    I made few serious test about that.
    Just set FC properly.
    rafael
    http://www.nagavideo.com
  • Matt Killmon
    April 25, 2009 at 5:31 pm
    Wait a second. You’re saying your sequence is progressive, so 23.976 progressive frames per second. If broadcasters want “interlaced” material, does that mean they want a 29.97 sequence with 3:2 pulldown already in it? In that case you’d be best exporting your sequence in its native format from Final Cut (full res, 23.976 progressive) and then using something like JES Deinterlacer to do the conversion down to standard def/apply pulldown (change frame rate) appropriately. Or, if JES’s scaler isn’t good enough, use another scaler to go down to 720 x 480 and then use JES to simply add the pulldown.
    I’m not sure I’m understanding the target format well enough though, so if when they’re saying “interlaced” they don’t actually mean “a 29.97 file with 3:2 pulldown from a 23.976 source) then never mind all that.
  • Göran Thorén
    April 27, 2009 at 6:21 am
    Matt:
    Sorry I don´t think I mentioned that this is a PAL project.
  • Göran Thorén
    April 27, 2009 at 6:24 am
    Dave:
    “Remember how nice the pictures looked?” Too long time ago for me to remember ; )
    But I do remember setting the it in “draft mode” to get a progressive look…
    Göran
  • Göran Thorén
    April 27, 2009 at 6:27 am
    Rafael:
    I have compared exporting SD from FC and doing it via compressor and the FC version look really bad.
    I do a standard quicktime export (not quicktime conversion) and choose 10bit uncompressed. How do you get it to look good?
    Göran
  • Rafael Amador
    April 27, 2009 at 10:13 am
    Hi Goran,
    Drop your 2K movie in an SD PAL sequence and set the codec to 10b Unc or Proress.
    In Sequence Setting set “Render Motion Effects: BEST”.
    This should helps with the downscaling.
    I guess your footage is 10b already. If your footage is 8b, set “Render all YUV material in High Precision”
    rafael
  • Göran Thorén
    April 27, 2009 at 10:28 am
    Thank´s Rafael! I will sure try this!
    Göran
Page 2 of 2
