Activity › Forums › Avid Media Composer › Exporting out as ProRes 4444
Michael Phillips
December 11, 2013 at 12:12 amYou need to have all the AMA clips highlighted (the one pointing to the new LogC 444 files) and the sequence. Right click the sequence and try again.
Michael
Blake Hester
December 11, 2013 at 5:02 pmOk, I think I’m missing something here. Let me explain what I have done so far:
– Copied the sequence and opened in a new bin
– Clicked “set bin display” and “show reference files”
– Copied only the DNxHD 36 files to a new bin, along with a copy of the sequence
– When I do the detailed sort, my Tape column has the 8 character REEL (A076R2N8)
– I went ahead and opened the Camroll and Labroll; columns and they have the full file name (A0761C002_120509_R2N8)
– I went ahead and picked an empty column, TapeID, and copied the 8 character names (A076R2N8) to that column
– Selected everything in the bin, right clicked and selected “relink”
– I have selected, Relink selected items to: “Media on Drive – All Available Drives”
– I have selected, Relink by: Original to Tape Name or Source File ID and Target to TapeID (I have also tried the labroll and get same results)
– when I select ok, it takes a few seconds to relink then I have a new sequence (or on some ways I have tried it, it says “no clips were relinked”), but the new sequence has the same DNxHD 36 files, not the ProRes 4444????
I will also note that I have all of my Avid sequences, files, .mxfs on one drive and all of the camera originals (ProRes 4444 files) on 2 separate drives, however they are all connected to the same computer.
I am certain that I am missing something simple because I am still trying to learn my way around Avid, or I may have explained something in the wrong way initially.
Either way, any help is greatly appreciated, I just need to have this file ready by the end of the week.
Michael Phillips
December 11, 2013 at 8:34 pmSince the sequence contains clips that already have the full 6 characters, you are all set. The next steps get a little wonky as it is not as straightforward as one would want it to be. I have heard of the process being referred to as “needing to be a relink whisperer”. It can be done with some tweaking. If you want to send me a zipped bin that has the sequence and all the clips you are trying to link to (AMA I am guessing?), I can try the relink to the clips and send back the bin. In theory, it would then relink to the media, but at the very least I can tell you what the settings need to be
michael[at]24p[dot]com
Michael
