Activity › Forums › Apple Final Cut Pro Legacy › Exporting is moving clips on my timeline
Immy Humes replied 15 years, 5 months ago 11 Members · 13 Replies
Rafael Amador
March 13, 2011 at 2:12 am[Immy Humes] “any thoughts anyone? i couldn’t fix it, can’t explain it. settings all seem correct. Tried exporting to .mov and several other formats, through Compressor and not, and all of them exhibit the same problem of slipping the clips. “
Which kind of stuff there is on your sequence?
rafael -
David Roth weiss
March 13, 2011 at 2:15 amAre you trying to edit h.264 from a canon or MP4 from a Flip cam???
If so, that’s a problem and you have to transcode to ProRes before editing or you will encounter issues.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Immy Humes
March 13, 2011 at 2:24 amThanks to you both David and Rafael.
I’m not v. well-prepared here, cuz I’m describing an issue one of my students had the other day, and i didn’t take notes.
But I’m pretty sure the media and settings were “normal,” – i.e. captured from HVD tape, with good settings.
What I had never seen b4 is a seq that plays fine and then exports with (some but not all) slipped clips. I’ve now found a few other cases in the forum.
https://forums.creativecow.net/readpost/8/1081662
https://forums.creativecow.net/thread/8/1038510#1038510
https://forums.creativecow.net/thread/8/1065801#1065801
Seems the only solution is to export and re-import the clips?
But don’t know what would have caused it in the first place.
Thanks for yr thoughts. I will double check everything after Spring Break.
yours truly,
Stumped TeacherThe Doc Tank, inc for documentaries
