Activity › Forums › Apple Final Cut Pro Legacy › Export seperate scenes from sequence
Bryan Zee replied 15 years, 3 months ago 5 Members · 13 Replies
Emma Rooney
May 17, 2011 at 10:42 amI dont know. Can you batch convert between markers to have seperate files?
Bryan Zee
June 3, 2011 at 5:23 pmHi Emma,
I am looking for the answer to this also.
I want a simple way to cut the timeline into pieces, batch export, and go to bed. In the morning I can distribute the movies.
It seems like a basic function that has been left out of FCP. Any suggestions?
Bryan Zee
June 3, 2011 at 5:38 pmHi Again Emma,
I just posted saying I was in the same situation as you. I took in some of the other suggestions as well.
I may have a solution.
If you separate the clips in the timeline to be exported, you can, (using the In/Out markers), individually create subclips, which can be individually named, and batch exported.
I am seeing if this works at the moment. Might be worth your time.
Zee
