Activity › Forums › Apple Final Cut Pro Legacy › Export FLV using Final Cut Pro
Greg Barringer replied 16 years, 9 months ago 19 Members · 31 Replies
Eric Hansen
July 28, 2008 at 3:24 pmPerian is a plug-in for Quicktime that allows it to playback more formats than Quicktime alone, such as FLV. it does not however support export. its playback only.
e
4 G5s, OSx 10.4.11, Final Cut 6.0.2, Kona LH (v5.1)
Xsan: Xserve 2.0 G5, 3GB RAM, 2 7TB Xserve RAIDs, Sanbox 5200
Quantum SDLT600A
decks: Sony HDW-M2000/10 HDCAM, HVR-M10U HDV with HD-Connect, DSR-1500 DVCAM, UVW-1800 BetacamSP
MacBook Pro: 2.33, 2GB RAM, OSx 10.4.11, Final Cut 6.0.2
cameras: Panasonic HVX200, Sony FX1 and A1U, Arri S/B 16mm
skis: Volkl Gotama 183s with 914s and Lange Fluid 120 boots -
Laura Cumbo
September 16, 2008 at 2:47 pmI had the same problem so I installed a 30 day trial of Adobe Flash CS3 and that put the .flv in my export window in Final Cut Pro….new problem, it doesn’t work!!! So I have to export to Quicktime and import it into Adobe Flash and convert it that way…at the end it says ‘Failed to complete’ but there’s an icon on my desktop of the clip in flv format and it works fine!
Does anyone know why this is happening?
Laura -
Sunita Sayana
October 10, 2008 at 1:40 pmHi I am trying to get the best possible quality video for my website for video shoots done in HD and edited in FCP.
My question is do I need to set anything in the advanced tab of visual hub?
Here is the process I use:
From Final Cut Pro I use QuickTime Conversation
File–>Export–>Using QuickTime Conversion
Click options
Click settings and:
Compression type: H.264
Quality: Best
Click OK
Click size and:
Choose custom, 480 X 270 px
Click the De-interlace button
Click OKI then drop the QuickTime file into Visual hub and select raw FLV checkbox.
Should I be doing anything with the advanced settings in Visual Hub?Thanks in advance!
Dan Enser
November 25, 2008 at 5:50 pmWe recently purchased Flash Pro CS4 for Mac, installed full program, restarted our system. Once we opened FCP 6.04 there was not an option in Quicktime conversion for a .flv file. What did we do wrong?
Elijah Lynn
December 4, 2008 at 6:07 pmWe have Flash 8 and FCP 6.0.5 and I have installed the Flash Media Encoder. Nowhere in any of the menus for Compressor or Export Using Quicktime Conversion is there a FLV option.
I just reinstalled Flash 8 and still nothing.
Any ideas?
Andrew Roger
December 12, 2008 at 1:25 amIf the flash component is truly installed, you need to click the little plus tab in the top right corner of the settings window and select Quicktime Export Components. It’ll pop up in your custom settings at the bottom. Click that and move to the browser where you can select FLV as well as many other non-quicktime based formats like WMV, AVI, Dvix, if you have them installed. If you mess with the settings, a non-FCP window will pop up. You’re actually using Adobe’s application under the guise of compressor. Make your settings, drop it on your clip and submit.
Hope that helps! -
Elijah Lynn
December 12, 2008 at 3:53 pmI’m linking another thread to this one to show screenshots of my dialogue menus. The FLV option is missing.
I reinstalled Flash once and I will try once more. Any other ideas?
Elijah Lynn
January 16, 2009 at 4:03 amLooks like I never crosslinked the thread. I recently installed Flash 9 (CS3) and I still do not have the option to export to FLV from within Final Cut Pro.
Here is the thread I started for my issue. Hopefully I will fix it soon and this will help some others.
https://forums.creativecow.net/thread/8/1014289
Jeff Toner
February 4, 2009 at 12:14 amHey Dan and everyone,
Just wondering if you ever found a solution to exporting an .flv from Final Cut Pro with CS4. I know that with CS3 installed you were given the option but when we installed CS4 Master Collection on a new computer there was no option within Final Cut to export an flv using the adobe flash encoder. Did Adobe drop this support in CS4?
Elijah Lynn
February 4, 2009 at 1:59 amHi,
I fixed it for CS3. Try the last post here. https://forums.creativecow.net/thread/8/1014289
Let us know if it works.
