Activity Forums VEGAS Pro Export file not working with Quicktime Pro
  • Mike Kujbida
    January 6, 2013 at 7:07 pm
    You need to go into the folder properties and change the settings so that you can see the file names.
    I only have XP but the procedure is similar in Vista and Windows7/8.
    Open up a folder and go Tools – Folder Options – View and deselect “Hide extensions for known file types”.
  • Mike Kujbida
    January 6, 2013 at 7:08 pm
    I forgot to mention that you need to click OK after doing this.
  • John Rofrano
    January 6, 2013 at 8:46 pm
    Yea, Microsoft though it would be funny to hide these from you. lol
    On Windows 7, open any Windows Explorer window and in the upper left, click on the menu item Organize | Folder and search options then go to the View tab and uncheckHide extensions for known file types“.
    Then you will see the file types again.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Kelly Ziolkoski
    January 6, 2013 at 9:21 pm
    jr…yeah, I’ve always used a 740 x 556 frame size. Works well for internet stream. I have tried all of the Sony AVC templates in Vegas 12 and none of them allow a custom frame size…only a few choices
    Kelly
  • Kelly Ziolkoski
    January 7, 2013 at 2:02 am
    Wow…I’m really baffled here. JR, none of those Sony Memory Stick templates allow you to do a custom frame size.
    Am I missing something?
    Kelly
  • Kelly Ziolkoski
    January 7, 2013 at 2:04 am
    Also, the choice of square “1” ASPECT FOR PIXEL is only in a few templates, not all
  • John Rofrano
    January 7, 2013 at 2:21 pm
    [Kelly Ziolkoski] “jr…yeah, I’ve always used a 740 x 556 frame size. Works well for internet stream. I have tried all of the Sony AVC templates in Vegas 12 and none of them allow a custom frame size…only a few choices”
    Sure it can. Start with the “Memory Stick SD NTSC – 6256 Kbps” template. Change these:
    Video Format: AVC
    Frame Size: (Custom frame size)
    Width: 740
    Height: 556
    Field Order: None (progressive scan)
    Pixel aspect ratio: 1.0000
    Like this:
    ~jr
  • Kelly Ziolkoski
    January 7, 2013 at 6:48 pm
    Right on JR! That works. Now I just need to make a custom bit rate and it won’t allow it. Only 4 choices for bit rate in your settings suggestion.
    Any ideas? I always like a bit rate of 1,500,000
    Thanks again!
    Kelly
  • John Rofrano
    January 7, 2013 at 7:33 pm
    [Kelly Ziolkoski] “Only 4 choices for bit rate in your settings suggestion. Any ideas? I always like a bit rate of 1,500,000”
    This gets by a lot of people because they see the drop down and think it’s a pick list but actually, it’s just a suggested list. You can type 1,500,000 in there if you’d like and it will use it.
    ~jr
  • Kelly Ziolkoski
    January 7, 2013 at 7:36 pm
    John…you absolutely freakin’ rock!
    Can’t thank you enough…especially for your patience.
    Take care
    Kelly
Page 2 of 3
