Activity Forums Sony Cameras EX-3 footage dropouts?
  • Anthony Bairstow
    June 9, 2010 at 3:20 pm
    Make sure your video playback quality in your sequence (top left of sequence, drop down) is on HIGH and not MEDIUM
    I found that this even effects playback in the viewer if you match frame or just watch ur clip back whole- not just the sequence and canvas
    This is tested on FCP 6 – not sure if 7 has this issue
    Good luck
    Anthony
  • Victor Virgilio
    November 10, 2011 at 12:07 pm
    What do you do when you have the drop out of the footage and no longer have the original sxs cards?
  • Victor Virgilio
    November 10, 2011 at 12:21 pm
    What do you do if the original sxs cards have been formatted? Am I now stuck with bad footage?
  • Bill Kimzey
    November 10, 2011 at 1:21 pm
    Did you, perhaps, make multiple copies from the card? If so, check other copies. One transfer may be bad, the other good.
    Does the problem appear if the file is played directly in Quicktime? If not, you might be able to export the problem areas from QTPro into a more robust codec, such as Prores.
    Depending on the severity of the problem it may be possible to manually composite good footage into the problem areas of your bad footage.
    But, ’tis best practice to use ClipBrowser or some third-party tool with copy-error detection (such as ShotPut) for at least the initial transfer from the SxS card to your footage drive.
  • Don Greening
    November 10, 2011 at 8:30 pm
    In addition to Bill’s sage advice, keep in mind that the camera may have actually recorded the bad frames (a rarity) and the fault is not with the integrity of the recording media. If this is the case then copying the clips using Clip Browser with CRC checking on or another third party program the bad frames will be faithfully reproduced in every detail.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
Page 2 of 2
