Activity › Forums › Adobe After Effects Expressions › encrypted expressions
Arun Chaudhary
January 27, 2017 at 8:35 amHi Den
wow your expressions work perfectly as all timeI’m new to expressions kindly explain how to get rid of the line breaks it is very important for me
Thanks, you are hero
Dan Ebberts
January 27, 2017 at 5:30 pmPut the cursor at the end of the first line and hit delete so the next line moves up, eliminating the break between those two lines. Repeat until the entire expression is on one line.
Dan
Arun Chaudhary
January 27, 2017 at 5:57 pmThis is wow wow Ohh Ohh my God
Den you saved my life
actually, I check every 10 minutes for your reply before I know where Den reply my problem solved
I’m now ????????????????????????????Thank you so much Den You are my hero
Mahmoud Elsafy
December 16, 2017 at 8:28 pmIs there a function that converts a text to binary instead of doing it manually in ExtendScript?
Nawaz Alamgir
April 16, 2020 at 12:33 pmHi dan, is there a way to reverse or decode an expression that has been encoding via the ExtendTool kit?
eval("@JSXBIN@ES@2.0@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"); -
Bjorn Levy
June 20, 2020 at 8:26 pmHey Nawaz, I want to decode an expression like that as well. If you don’t mind me asking, how have you managed to do it?
