Activity › Forums › Adobe Encore DVD › Encore Scroll Menu
Anne Muun
August 31, 2008 at 12:15 pmI tried burning 2x speed, but that didn’t make a difference.
How can I see the bitrate?
Jeff Bellune
August 31, 2008 at 1:08 pmThere are 2 free tools you can use:
Don’t worry about the Quicktiome playback module for MPEG Streamclip, you can find out the bit rate info without it.
Bitrate Viewer is usually excellent, but sometimes it gives odd results. It’s a good idea to run your clips through both programs and examine the results. It takes MPEG Streamclip a long time to examine your file (about 10 – 15 minutes for a 2-hour clip). Bitrate Viewer takes about 5 minutes for a 2-hour clip.
Any Peak bitrate over 9 Mbps in Bitrate Viewer is cause for concern. I would be worried about anything over 8 Mbps reported by MPEG Streamclip.
-Jeff
The Focal Easy Guide to Adobe Encore DVD 2.0
Anne Muun
September 28, 2008 at 8:49 amThe Bitrate was (under ‘Peak’) 12119.
What can I do to fix it so I can finally burn the dvd in good quality?
