Activity › Forums › Avid Media Composer › Encoding to H.264 from DNxHD with Squeeze 7
Ra-ey Saleh replied 14 years, 10 months ago 4 Members · 15 Replies
Ra-ey Saleh
November 17, 2011 at 2:19 amAs Job has detailed perfectly, the H.264 Gamma Shift if pretty famous and very annoying. It’s more prevalent with files created on a PC as well.
And the MainConcept H.264 encoder that is in Squeeze 7 upwards is really a thing of beauty. Stunning and no real Gamma Shift (or at least not really noticable)…
You can download some presets here that might be a good starting point:
https://exchange.sorensonmedia.com/Ra-ey
Ronn Kilby
November 17, 2011 at 5:15 amThanks Ra-ey – I just purchased the Squeeze 8 upgrade but have not yet installed. Could you specify a particular preset that would be optimal for DNxHD to H.264 HD?
Ra-ey Saleh
November 17, 2011 at 5:31 amWhat’s the source spec and destination spec you want and I’ll see if there’s a preset already made.
Ra-ey
Ronn Kilby
November 17, 2011 at 3:18 pm1920×1080 59.84i DNxHD to 1920×1080 59.84i H.264, best quality.
Ra-ey Saleh
November 18, 2011 at 1:33 amRonn,
I’ve tweaked a preset I downloaded from Sorenson Exchange by Coby Rich to make it Interlaced for you.
Just double-click the file and install it in the default location. You’ll find it when you open up Sorenson in the Favourites tab.
I set the Audio to 44, but you can easily change it to 48.
Also, tweak any other settings you want.
Let us know if it works for you.
3272_mp4mainconcepthd1080i.spfx.zipps. I used the original preset to encode my reel and got much better results than using any other encoder (i.e. Compressor, Streamclip). Have a look (shameless plug!)
https://vimeo.com/30945433Ra-ey
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
