Activity › Forums › Apple Final Cut Pro Legacy › Emailing full video file for client
Kevin Monahan replied 17 years, 8 months ago 11 Members · 15 Replies
John Fishback
December 20, 2008 at 7:49 pmYou can xfer up to a 2GB from YSI for a one-time $8.99 charge. It’s the Premium Delivey option.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Andy Mees
December 21, 2008 at 1:53 amHi Rafael
I did some tests recently with a shooter in Hong King who was using an EX3. Got him to export / compress a 30″ native codec test sequence:
1. using MPEG Streamclip to convert to MPEG-4 / H264 scaled to SD frame size
2. directly from FCP to SD H264 using Quicktime Conversion
3. using MPEG Streamclip to convert to MPEG-4 / “Apple MPEG4” scaled to SD frame size
4. using MPEG Streamclip to convert to MPEG-4 / H264 unscaled (ie maintaining HD frame size)No. 4 was the runaway winner. The picture quality and general definition was vastly superior to the others, it held up the best during motion within the frame, pans and zooms, and surprisingly it also produced the smallest file size of the methods tested. If I were to rank them in order of overall quality it would be as below:
1st – 4. (47.9MB)
2nd – 1. (55.3MB)
3rd – 3. (73.7MB)
4th – 2. (53.2MB)So no, not specifically for compatibility but because it looks good and sends faster!
Cheers
Andy -
Rafael Amador
December 21, 2008 at 3:18 amHi Andy,
Thanks for the info.
Very interesting test. I’ll give it a try.
Cheers,
Rafael -
Joppo Te veldhuis
December 21, 2008 at 4:07 pmjust do a 8bit/10bit uncompressed qt render. and then zip it in the finder (rightclick-compress…). you will be amazed about the decrease of size 🙂
Kevin Monahan
December 21, 2008 at 6:54 pmI agree with joppo. Send the uncompressed version and zip it.
I would happily pay even 10 bucks to send this file and get it off my plate.
That kind of money is really small for pros that visit this forum.Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro
