Activity › Forums › Apple Final Cut Pro Legacy › Editing a ProRes file
  • Walter Biscardi
    January 10, 2010 at 3:17 pm
    [Scott Aigner] “It is only when I import it to the project I am currently working on and drag it down into the timeline (which already has edits at the beginning of the timeline of different files (some of which are ProRes) does it say that I need to render it.”
    That’s your problem. The Sequence settings are already set. Those clips that match that Sequence will play in real time, those that don’t, won’t.
    You say you have a hodgepodge of clips you started with. Were they all exactly the same frame size, same frame rate and all interlaced or progressive?
    If any of those clips do not match exactly the Sequence, then they will not play in Realtime unless you have your Sequence set to Unlimited RT AND you have a fast enough media array to play the clips in realtime..
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
Page 2 of 2
