Activity › Forums › Apple Final Cut Pro Legacy › Editing 8-bit uncompressed in FCP
  • Peter Dewit
    November 29, 2007 at 2:37 pm
    Just playing or editing the footage will not be a problem through a firewire 800 drive. Where you might start seeing some slowdown or slow renders is if your sequence is complicated with many video layers and effects.
    If it’s a fairly straightforward edit you should be ok.
  • Chris Borjis
    November 29, 2007 at 5:04 pm
    [Michael G] “BTW Can we draft a protocol for acronyms?”
    Yes!
    Lets not use them at all! 😀
  • Corey Frey
    November 30, 2007 at 12:03 am
    I edit in the style of being anti-many layers, I try to keep the main picture edit on one layer so if thats the case then this sounds good and should flow pretty well.
    Thanks guys for your input and help
  • Corey Frey
    November 30, 2007 at 12:04 am
Page 2 of 2
