Activity › Forums › Adobe Premiere Pro › edit with h264 or transcode?
  • Michael Murphy
    June 12, 2012 at 2:04 am
    It sounds like you will be able to color correct/grade in Premiere for basic needs.
    I think you mentioned using Warp Stabilizer earlier in AE? If you are upgrading to CS6, Premiere Pro now has Warp Stabilizier & somewhat easier color correction.
    Might be easiest on this round to just stay in PP, rather than going to AE or Speedgrade. CS6 is a great package!
    Good luck.
    Michael
  • Juan Stewart
    June 12, 2012 at 5:29 am
    Thanks Michael! I kno, CS6 would be great. But don’t know if I’ll be able for this project…
  • Nate Mclean
    August 23, 2015 at 9:08 am
    How does one color grade 10-bit Prores footage from the GH4 + Atomos Shogun in After Effects on a PC without rendering out washed out image? Seems like the PC does not want to render the same color saturation and contrast as I see in the After Effects panal. Is this because PC is not reading Prores correctly? Can I just export to some different codec? Or must I transcode all the footage from the prores to something else when working on a pC? Thanks so much!
Page 2 of 2
