Activity Forums Apple Final Cut Pro Legacy Echoed images
  • Gennaro Ambrosino
    August 12, 2010 at 11:45 am
    1440×1080
    upper (odd)
    editing timebase: 25
    quicktime video settings / compressor: hdv 1080i50
    Gennaro
  • Gennaro Ambrosino
    August 12, 2010 at 12:41 pm
    any thoughts? thanks
    Gennaro
  • Rafael Amador
    August 12, 2010 at 1:10 pm
    Delete the “Constant Frame” renders and try again.
    rafael
    http://www.nagavideo.com
  • Gennaro Ambrosino
    August 12, 2010 at 1:44 pm
    thanks for the suggestion…unfortunately it’s still the same 🙁
    Gennaro
  • Adam Taylor
    August 12, 2010 at 1:47 pm
    I thought that HDV (like DV) is a Lower Field first format ?
    – you have yours in upper field first – so you are seeing the fields in the wrong order – which might account for the echo
    adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
  • Gennaro Ambrosino
    August 12, 2010 at 2:11 pm
    thanks a lot Adam, but it doesn’t seem to solve the problem…
    Gennaro
  • Rafael Amador
    August 12, 2010 at 4:08 pm
    [adam taylor] “I thought that HDV (like DV) is a Lower Field first format ?”
    All the interlaced HD formats are Upper.
    rafael
  • Sven Giebel
    August 12, 2010 at 9:01 pm
    Did you shoot with shutter on? Although the cameramovement is pretty rough, every single field looks sharp. there seem to be time differences between picture and echo. Are you aware of the fact, that FCP will show only single fields when you look at the canvas not in 100% mode? Maybe you see only what you shot…hm.
Page 2 of 2
