Activity › Forums › VEGAS Pro › easier way to do this?
  • Graham Bernard
    May 14, 2016 at 7:03 am
    Solo just that track and render it out. Apply the FX. Done.
    * Grazie
  • Graham Bernard
    May 14, 2016 at 7:09 am
    I’m assuming you know you would need to render to a Format that has a transparent background, otherwise you’d blank the lower tracks. Yes?
    * Grazie
  • Graham Bernard
    May 14, 2016 at 8:43 am
    Oh yes… The easiest way is to make this Event part of a 3D Parent Track and use that as the moving section.
    * Grazie
  • John Rofrano
    May 14, 2016 at 1:38 pm
    Graham, I believe what Ellie is trying to do is map a static image onto a moving video. To do this in an easer way would require Motion Tracking software that tracks perspective. Those are expensive like Boris Continuum Complete or Mocha Pro.
    The cheap way is the hard way which is to move frame by frame and keyframe the motion in Pan/Crop. There is no short cut. You need more keyframes to keep everything in sync.
    Here is a tutorial on using Match Move in Boris Continuum Complete but that doesn’t track perspective and the buildings are moving not only sideways but away into the distance which requires perspective tracking.
    https://www.youtube.com/watch?v=6YvYJuHoVp0
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Graham Bernard
    May 14, 2016 at 2:50 pm
    Hi John. How about my last suggestion? Have the Still and the FX as Children to a Parent Track and then 3D that Parent track? But otherwise the power of Boris would need to be used.
    * Grazie
  • John Rofrano
    May 14, 2016 at 2:58 pm
    [Graham Bernard] “How about my last suggestion? Have the Still and the FX as Children to a Parent Track and then 3D that Parent track?”
    That would only work if both tracks were being animated. They are not. His lower track is a movie. That requires motion tracing software.
    ~jr
  • Ellie Mercer
    May 14, 2016 at 10:24 pm
    yess thats exactly what im trying to do i have a different way that ive thought of now but thank you for your help!
  • Graham Bernard
    May 15, 2016 at 5:16 am
    [ellie mercer] “i have a different way that ive thought of now but thank you for your help!”
    You’re welcome. What did you come up with?
    * Grazie
Page 2 of 2
