Activity › Forums › DVD Authoring › DVD Lab Pro – Menu loop points and linking
Abraham Chaffin replied 18 years, 11 months ago 3 Members · 12 Replies
Eric Pautsch
September 20, 2007 at 9:59 pmNot thats it’s bad but mixing different resolutions from menu to titles and vice versa is not good. I also understand some players balk at this frame resolutions.
My main concern is the amount of money involved, the tools and techniques your using and if you feel OK about using a tool which the designers say shouldn’t be used for anything other than home use 🙂
No authoring app is perfect and I’ve only used DVD-Lab once to check out it’s abstraction layer but based on that comment from them I see “zero” chance of using it in a professional environment.
Abraham Chaffin
October 9, 2007 at 10:49 pmThe COW now has an edit button – after you post – click on your post (not the thread) and right below your post there will be an edit button. This is only available for 30 minutes after you have posted and before someone replies to the post.
Take care,
