Activity › Forums › Apple Final Cut Pro Legacy › DVC Pro 50 Problem That Needs Immediate Attention
Scott Thomas replied 19 years, 4 months ago 6 Members · 12 Replies
Ed Dooley
May 17, 2007 at 6:32 pmThanks! You’d think with us being video/film people and all, we could prove that we laughed by providing a youtube link of us actually doing it. We could use a web cam, unless, of course it’s a ROTFLOL; the cam wouldn’t see it. 🙂
Ed -
Scott Thomas
May 19, 2007 at 3:18 amI had this same problem with DV50 and an AJ-SD93. I actually found the answer here on the COW in the archives.
My solution was to batch capture (just one large clip in my case) instead of “Capture Now”. For some reason, actually marking the in and out points for the clip forced FCP to use the correct sample rate for the clip.
I would bet you that either way, the capture was just fine. Just something got screwed-up in the metadata of the file that told Quicktime the wrong sample rate.
Is there a utility out there to edit Quicktime metadata without changing the data contents of the file? Like pixel aspect data or anamorphic?
