Activity › Forums › Adobe After Effects › Duplicate a pre-comp and make it independant?
Joshua Bartyzal replied 6 years, 9 months ago 19 Members · 19 Replies
Nick Hasselblad
August 9, 2017 at 5:36 pmThanks – – your answer still applicable and greatly appreciated here in 2017.
Goran Milovanovic
August 26, 2017 at 7:15 amNeverovatno gde se sve ljudi srecu! Zaboravio sam ono ALT ☺ Pozdrav momce!
Remus Hosu
August 26, 2017 at 5:47 pmYou need to duplicate the comp in the Project Panel and also duplicate it in the comp panel. Next, with both layers selected, press “Ctrl+Alt+/” or “Command+Option+/” on macs to replace it. The only caveat is that if your precomp has precomps of it’s own inside, you will need to duplicate those as well using the same technique. Here’s exactly how to do it step by step:
https://bluefx.net/how-to-duplicate-composition-in-after-effects-correctly
and if you really want to automate the process, there’s a very cool AE script you can use, True Comp Duplicator:
https://aescripts.com/true-comp-duplicator/
Cosima Niehaus
April 12, 2018 at 1:19 pmEasy:
1- Create a new folder and insert all the compositions that you need to duplicate in it.
2- Duplicate the folder
3- Rename all the compositions inside the duplicated folder.🙂
Michael Kurz
June 26, 2018 at 11:43 pmCosima,
I think your process only duplicates everything in the project folder. It does not replace nested precomps with the new duplicated versions, i.e. the duplicated parent comp still contains the original precomp rather than the duplicated precomp (even though there is a duplicated precomp in the project folder). Anyone know an easier way than duplicating everything and then swapping out every precomp [tedious]?
http://www.freelancebymichael.com
Aindreas Gallagher
June 27, 2018 at 10:20 amTrue Comp Duplicator – better than the entire Boris FX suite imo. Really simple life changer.
Particularly if say you’re adapting a complex existing project – just true comp duplicate the master comp and hey presto – you’ve got a safe second version to mess around with.
https://vimeo.com/user1590967
producer/editor.grading/motion graphics -
Joshua Bartyzal
November 29, 2019 at 11:33 amAn additional bit of advice now that you’ve figured it out.
Master Properties/Design Essentials are great for this sort of thing if you plan ahead for using them when initially setting up your design (as we all know, easier said than done, design is evolution, ugh)
https://www.youtube.com/watch?v=H1ZsiQy764QSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
