Activity › Forums › Avid Media Composer › Duplicate a clip in the TL
  • Shane Ross
    October 8, 2013 at 4:31 pm
    I can do it in four steps.
    1) Lasso the clips I want
    2) Copy
    3) Put playhead where I want it to go.
    4) Paste.
    Not all NLEs do things the same way. That’s something we need to get used to.
    Shane
    Little Frog Post
  • Olivier Prudhomme
    October 8, 2013 at 4:50 pm
    but you still end up with a clip that will overwrite anything that’s on its way.
    What would be another way to duplicate a clip.
    I thought of match frame to recall the clip in the compose window but I can’t get the Out point.
    What would you guys do if you had to use add a same clip in a timeline after you’ve already did some work, implying you could not just paste the clip w/o overwriting media.
    Or another way to put it: Let say at the end of your project you want to add the same woosh to several transitions but since you have so many layers you can’t just “paste” it. How would you add this woosh?
  • Shane Ross
    October 8, 2013 at 4:57 pm
    Do what John Pale suggested. The setup will require a few more steps, but end up quick. Mark IN and OUT around the clips you want, with those tracks selected. Hold ALT and press the C key. Or…do what I do and have ALT and CONTROL mapped to the C key so that all you do is press C and BOOM, that IN and OUT area is instantly loaded into the viewer.
    Map the tracks to where you want to target….so you don’t over-write anything you don’t want. Now you are set up…insert or overwrite away.
    Sorry it’s not as easy as another NLE. This is the best I can come up with.
    Shane
    Little Frog Post
  • Olivier Prudhomme
    October 8, 2013 at 5:33 pm
    I like that!!
    I’ll try
    thx all
  • Michael Phillips
    October 8, 2013 at 11:22 pm
    I agree that’s how it should work which follows the logic of source to record monitor anyway –
    Michael
  • Olivier Prudhomme
    October 9, 2013 at 12:03 am
    Opt-Copy works nicely!!!
    Thx guys!
Page 2 of 2
