Activity › Forums › DSLR Video › DSLR video and Final Cut Express
  • Jonathan Ziegler
    April 2, 2010 at 8:47 pm
    24p 2:3 pulldown will skew the fields – 24pa with the 2:3:3:2 pulldown will give you whole frames to convert to a true 24fps versus 24p at 23.976 fps. Perfect for making a print to film if you plan to go that route. If you never plan a film print, 24p is fine (and I honestly don’t see film lasting for widespread use longer than 15 more years), but I don’t like the way 2:3 pulldown works versus 2:3:3:2. Also, I know this is pushing it a bit, 2:3:3:2 is way better if you plan to do special effects – easier to put the fx on a whole frame than 1 frame split into separate fields on 2 frames – use 24pa instead, reverse pull to 24fps, then edit. It could just as easily shoot true 24fps and then I’ll convert to 24P in the edit for video.
    Jonathan Ziegler
    https://www.electrictiger.com/
    520-360-8293
Page 2 of 2
