Activity › Forums › Apple Final Cut Pro Legacy › Downside to “Abort Capture on Dropped Frames”?
Fredy Schwerdtner replied 15 years, 7 months ago 8 Members · 14 Replies
Raven Plenty
October 30, 2008 at 5:32 pmNo, sadly it’s all on one hard drive right now. This will be changing soon. What won’t be changing soon enough for me is the move to a non-tape camera in our office. Real-time capturing sucks, dropped frames or not.
You know that bungee thing looks pretty fun, even if it is going nowhere fast!
Thanks again.
Damien Barnecutt
November 22, 2008 at 1:14 pmI have just left a post at:
https://forums.creativecow.net/readpost/8/1012393
But basically try a different / lower monitor screen resolution.
If this helps anyone I would be interested to know, with or with the same hardware.
Damien
Lupo Zin
October 18, 2009 at 8:48 pmquote from fcp help:
Abort capture on dropped frames: When this option is selected, capture stops immediately when a dropped frame is detected. All media captured before the dropped frame has frame-accurate timecode and is preserved. The resulting media file is saved and a clip for that media file is placed in the Browser.doesn’t that mean that everything till the the dropped frame should be saved in the browser?
also, why is it important for the Mac OS extended hard drive not to be journaled?
thanks,
Lupo. -
Fredy Schwerdtner
February 5, 2011 at 6:36 pmhi Rafael,
Do you think I should do the same for capturing from VHS to avoid stop the capture process ?
thanks.MacBook Pro 17″
2.5 GHz Intel Core 2 Duo
4GB 667 MHz DDR2 SDRAM
(2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
OS X 10.6.5
Final Cut Studio “3”
