Activity Forums Apple Final Cut Pro Legacy Down converting quicktimes.
  • Shane Ross
    July 9, 2010 at 11:07 pm
    I can insert edit fine too. Well, not 100%…that’s a bummer. Closer to 85%. But betaSP inserts is the big issue. 25% accuracy…horrid. Digi, HDCAM SR…85-90% Insert. Yeah, not the best. Avid is better. I black the first two min of a tape, then Assemble edit…with black at the end.
    Shane
  • Jerry Hofmann
    July 10, 2010 at 1:32 pm
    When you make an assemble edit, the TC track is re-recorded, and the out edit will not be particularly “clean”… so thus the black at the end of a layoff – the out point of this edit is way off the end of the program. I usually only black about 10 seconds on the front of a new tape, then assemble edit starting 5 seconds before the black runs out. If I have to lay off again though, it’s the whole show again using another assemble. Start the TC at say 58 minutes, then setup the edit so the program starts at 1 hour…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17” MBP, Matrox MXO2 with MAX Cinema Displays
Page 2 of 2
