Activity › Forums › Apple Final Cut Pro Legacy › Does this BUG still exist in FCP 7?
Rafael Amador
September 17, 2010 at 4:56 pm[Miodrag Ristic] “I know how to “Show Clip Properties”, but where do I go to change them?
Click Video Track > Visual setting
Uncheck Preser aspect ratio and set 960 x 720.
rafael -
Miodrag Ristic
September 17, 2010 at 5:21 pmI did that, the settings are fixed in the browser, but I still get the red render bar
and footage looks jittery in the browser.Why that other project worked fine,
as I explained earlier.Only thing different between those two projects is that problematic one has
psd file and another still.When I was importing psd file I even tried to that correctly and created a file with HDTV setting.
Before that transferred layers from original psd file provided from client’s graphic “designer”, as I noticed some weird things, like vector graphics, just didn’t look right… I don’t know… -
Terry Mikkelsen
September 17, 2010 at 5:27 pmInteresting problem, but odd way of trying to solve it.
To add something (an effect) to an entire sequence, nest the sequence into a new sequence. Or in this case, with burn-in needed, I would have just re-encoded with Compressor but added the “Timecode Generator” filter that Compressor provides.
Tech-T Productions
http://www.technical-t.com -
Miodrag Ristic
September 17, 2010 at 5:34 pmPlease, that TC thing is not the issue.
The issue is: a sequence exported as Quick Time movie, current settings, not recompressed SHOULD
be exact copy of the timeline, so it should re-import as a native file – NOT with red rendered bar. -
Terry Mikkelsen
September 17, 2010 at 5:41 pmBut I’m struggling with a reason as to WHY I would re-import a QT file.
Tech-T Productions
Miodrag Ristic
September 17, 2010 at 5:50 pmIt’s same like if you asked me why would I want a car that can go 180 km/hr when maximum allowed is
110…Firstly, If you ever made a demo for example and wanted a clip included from a various projects, maybe 10 or more, you’d grab parts of those competed projects and import them into new project/ timeline.
Secondly, you might sometime need a part of project previously done for a clint and add to something else…
John Pale
September 17, 2010 at 5:59 pmback when this bug first reared its ugly head under FCP 6, I found that adding a meaningless filter (color correction with no change in settings) to the offending clips (in this case, the PSD files), then rendering, would then make the timeline’s export work correctly. FCP would use the render file’s pixel aspect (which would match the DVCPROHD timeline) instead of the PSD’s pixel aspect.
Give it a shot.
You should definitely report this bug to Apple ASAP.
Miodrag Ristic
September 17, 2010 at 6:00 pmRafael, I’m getting somewhere… I exported a small portion of the timeline without problems when reimported.
All as it should be, Pixel Ratio, Frame Size and no render bar.I’m going slowly with different parts of the timeline until I can narrow down a culprit.
It looks like, the stills are not the problem as I first deleted them in this timeline.Hopefully I’ll get to it, I remember how Lumiere concluded it’s just random… hopefully
I’ll get firther… uh… it’s 4 am here…Mio
Miodrag Ristic
September 17, 2010 at 6:14 pmDoesn’t work unfortunately.
Tried already a timeline with no graphics and still happens.
My last positive shot was a piece of timeline, random, small, and it came back just fine.
Mio
Miodrag Ristic
September 17, 2010 at 6:46 pmFound it!
Doesn’t like any graphics or even text subtitle or lower thirds like Matte – Colour to place under the text.
If clips chosen of pure video, no problems, but if there is anything else on top a clip – no go.
comes back as “Square” Pixel Aspect and 1280×720 (instead of 960×720.
Tried that with applying a random filter what John suggested, but it doesn’t work.Well, that’s only half a job, is there a workaround…
I leave it for tomorrow, it’s 4:50 in the morning here, what a night…
Thank to everyones for help.
Mio
