Activity › Forums › Panasonic Cameras › DOES FCP 6 EDIT MXF NATIVELY?
  • Marcus Van bavel
    May 25, 2007 at 9:54 pm
    [Joe Murray] “I’ve used Raylight in Premiere with MXF files, and I always have to render the files in Premiere before they’ll play realtime. This may be a limitation of my system; I don’t know for sure because I don’t use Premiere very often. Seems to take about the same amount of time to render a file in Premiere that it takes to import the file into FCP, so not a great timesaver for me. Does anyone have different experience with Raylight, i.e. native support and realtime playback in Premiere?”
    Here is a table of expected performance with Raylight 3.0:
    https://dvfilm.com/raylight/raylightSpeed.htm
    For example 720/24P in Draft/Green you should be able to get
    real time with dissolves, etc without rendering, no problem.
    If you get much different results contact DVFilm Support.
  • Lt Kije
    May 29, 2007 at 4:04 am
    Can’t say I recommend Raylight.
    The version I tried :
    * Doesn
Page 2 of 2
