Activity › Forums › Apple Final Cut Pro Legacy › Do I need more RAM?
  • Nick Ryan
    March 2, 2006 at 4:32 pm
    Ah! So it doesn’t sound normal! Good – we finally have something to work with. We’ll start investigating the drive. Thanks!
    Nick
  • Nick Ryan
    March 2, 2006 at 5:43 pm
    Hmmm. Took the AJA system test across the hall and tested the read/write speeds on a different system over there. Both the read and write speeds over there are over 200MB/s – quite a difference from my system, reading @ 175 and writing @ 46. We swapped out my ATTO SCSI card to see if it was that – but my read and writes are the same…
    The quest continues.
    Nick
  • Jeremy Garchow
    March 2, 2006 at 5:55 pm
    Yup, sounds like maybe one of your drives is either down or running slow. Does it have any RAID protection, a la RAID 3 or RAID 5?
  • Nick Ryan
    March 2, 2006 at 7:41 pm
    No, it’s merely striped.
    Nick
  • Nick Ryan
    March 3, 2006 at 9:56 pm
    Just to follow up…
    We used the AJA system check to test a 3rd FCP workstation – which also had very high read and write speeds. The 3rd workstation and I share the same version of Tiger – so it doesn’t seem to be that. We took the G5 across the hall and connected it to the 2nd Medea to check whether it was a Medea issue or an internal issue – read/write speeds were even slower than they were originally. We’ve already swapped the SCSI so we know it’s not that. This brings it down to a software conflict or a piece of bad hardware somewhere…
    Nick
  • Jeremy Garchow
    March 3, 2006 at 10:09 pm
    So, you took the drive set over to another machine and got over 200 MB/sec on the same exact drives?
    Hmm, curious.
  • Nick Ryan
    March 6, 2006 at 2:48 pm
    No… not on the same exact drives, but rather on an identical Medea array… We still have yet to test this array on a different machine.
    Nick
  • Nick Ryan
    March 6, 2006 at 7:19 pm
    Just to clarify…
    The throughput on my machine (Machine 1 & Medea 1) is writing around 46MBs and reading at 175MBs.
    The throughput on the machine across the hall (Machine 2 & Medea 2) is reading/writing over 200MBs.
    The throughput on my machine with the other Medea (Machine 1 & Medea 2) is writing around 40MBs & reading around 165MBs or so (don’t remember this one exactly but remember that it was definitely slower than the original arrangement).
    Nick
  • Jeremy Garchow
    March 7, 2006 at 3:20 am
    Thanks for the clarification. Have you tried different SCSI cables/terminators, or perhaps you should swap them (it is a dual channel configuration, no?)
    Jeremy
  • Nick Ryan
    March 7, 2006 at 2:32 pm
    When we took my machine across the hall we just unplugged all attatched cables, took it over, and plugged in all the cables over there (identical setup); so that test was a different Medea as well as different cables. The SCSI card has already been swapped on a previous test – didn’t change anything.
    Nick
Page 2 of 2
