Activity › Forums › Adobe Premiere Pro › DLSR: edit native or ProRes. With intent to export ProRes as final, digital master on Export?
Max Sainvil replied 12 years, 8 months ago 10 Members · 22 Replies
Ivan Myles
May 2, 2013 at 11:28 pm[Kevin Duffey] “So I should be safe if/when I can record with a BM Pocket Camera or Cinema Camera that records in DNxHD right?
“I will have to do some extensive testing. Send over your cameras and I’ll take a look. 🙂
Max Sainvil
December 22, 2013 at 7:41 pmI’m not really savvy when it comes to all these codecs, YCbCr/RGB talk…
I’ve learned a lot from reading this but it’s still not clear to me.
So basically I just started using FCPX. My question is, would editing Native h.264 then doing heavy coloring/grading and exporting as h264 or Pro Res is the same as transcoding native h264 to Pro Res before editing… then applying heavy coloring/grading then export as h264 or Pro Res? I know it’s not adding any detail, but doesn’t Pro Res expands the color range and file size to gives you more freedom to color correct and grade? Almost like a dry sponge being soaked in water?
Max
http://www.youtube.com/maxsainvil
