Activity Forums Adobe After Effects Expressions Divide by zero? error on first frame
  • David Cabestany
    May 6, 2016 at 3:42 am
    I could keyframe it but then I’ll have more keyframes to tweak when the values change per the client, the more keyframes the more opportunity for errors to happen.
    What I’m trying to do is to have a minimum amount of keyframes (in this case only two) and have the entire comp update all the values in all the layers based on just this two keyframes.
    Everything is working as expected except for this layer, I have basic additions, this percentage values and a couple circles that complete accordingly to the percentage, if I change the value of the end keyframe everything updates automatically, except for this single layer.
    Best,
    D.
  • David Cabestany
    May 6, 2016 at 3:46 am
    Everything is working as expected except for this layer.
    Edit: I just fixed it. When you mentioned that the linear expression is acting as a bridge, I changed it for an ease expression, now it is animating as expected.
    Still very perplexing, though.
    Thanks a lot for your help Dan.
Page 2 of 2
