Activity › Forums › Adobe Premiere Pro › Different FPS??
Anna Holck
November 17, 2014 at 5:20 pmThanks! But just to be all clear, won’t it loose quality in that way that it get’s stretched out to fit the size? Og is that the other way around, 1080p to 720p?
Shane Ross
November 17, 2014 at 5:25 pmIf you shot 720p50 and you blow that up to 1080p25…yes, you will lose “a little” quality. A LITTLE. Premiere Pro actually is the best editing app for scaling footage. It does it better than anything else out there. I use it to scale footage for use in other editing software.
yes, you will lose a little quality. But I doubt you’d be able to tell.
If it’s 1080p50, then no, you will lose NO quality…not zooming in at all.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Anna Holck
November 17, 2014 at 5:34 pmSo if was to make an music video where Almost all the video slips are 25 FPS, and also the sequence. And i have these few video clips that are 50 FPS. Do i just then drag them in the 25 FPS sequence and click ”Keep excisting settings” And right click on the click and ”Scale to frame size” ? Is that the way the proffesionals do it? will it then loose quality if you do the ”interpret” thing INSTEAD of dragging it in and ”keeping existing settings” ?
Shane Ross
November 17, 2014 at 5:37 pm[anna holck] “Do i just then drag them in the 25 FPS sequence and click ”Keep excisting settings” And right click on the click and ”Scale to frame size” ?”
Yup.
[anna holck] ” Is that the way the proffesionals do it?”
Yup.
[anna holck] “will it then loose quality if you do the ”interpret” thing INSTEAD of dragging it in and ”keeping existing settings” ?”
Nope. If you do the INTERPRET thing, you will make the footage slow motion. Do you want slow motion, or normal speed? ONLY USE INTERPRET IF YOU WANT IT TO BE SLOW MOTION. Otherwise, just drag the clip into the sequence…it will play normal speed.
Shane
Little Frog Post
Anna Holck
November 17, 2014 at 5:43 pmI want it to be slowmotion, but i want to do it with Trixtor in after effects (So i just import the files from premiere pro to after affects and back again) What will that do if i make it slowmotion there? So if we say have dragged the clip into the timeline and click ”Keep excisting settings” And interact it with after effects to aplly trixtor slowmotion on there, go back and then the slowmotion is applied, will it then loose quality? I am sorry that i don’t know this very well (:
Mark Norgate
November 17, 2014 at 6:16 pmI didn’t realise that. Be good to know how it loses quality by upscaling if the explanation isn’t too technical for a monday evening?!
Shane Ross
November 17, 2014 at 6:19 pmWell, if it’s 720p…1280×720…and you blow it up to 1920×1080…then you’ll lose a little quality. The explaination isn’t all that technical…anytime you blow up anything, it’ll lose quality. You are making the pixels bigger…so they will get softer.
Shane
Little Frog Post
Anna Holck
November 17, 2014 at 6:25 pmAnd also when you interpret you 50 FPS to 25. Can you further adjust the slowtion speed? And how? And i’m assuming that that won’t make it loose quality either?
Shane Ross
November 17, 2014 at 6:26 pmFor anything AFTER EFFECTS, I’ll leave that to the AE gurus. I barely know it, and don’t use Twixtor.
Shane
Little Frog Post
