Activity › Forums › Blackmagic Design › DeckLink & Multibridge Windows 5.7 drivers released — JPEG support
Igor Babic replied 19 years, 11 months ago 10 Members · 14 Replies
Bill Buchanan
September 27, 2006 at 2:59 pmThanks, Leo. The clicks I’m dealing with are not like those of yours. The sound engineer seems to believe that my clicking issue may have something to do with a component trying to re-sample the audio coming in. We have not yet tracked it down, but it apparently is not a result of same causes/issues you were dealing with. In my case, I’m converting DV (24p) originated footage/sound to 10-bit uncompressed avi, bringing into PremPro 2 via SDI using a SD-Connect converter. Somewhere along the line, the clicking is being introduced, which to me is inaudible, but it’s driving the engineer nuts.
Bill Buchanan
Buchanan Film Co. -
Igor Babic
September 27, 2006 at 4:44 pmThanks. I am aware of that. Did try to route thru Betacam SP but picture was rolled down. I will try tomorow thru my old DPS PVR that has TBC on input, but I have read somewhere on DL manual or site that composite VHS capture is possible without TBC.
Rahni
September 28, 2006 at 9:49 pmThe Decklink dont like unstable composite signals at all. The only solution for me was to pass it thru my DVD recorder, having YUV outputs, to feed my YUV inputs of the decklink extreme and everything works well.
I captured a lot of “historical” VHS footage that way. good luck!hr
