Activity › Forums › Apple Final Cut Pro Legacy › Deck Capturing Odd Framerates
Michael Cummins
November 24, 2008 at 9:17 pmThanks for the response. Glad to know I’m not the only one in this boat.
UPDATE! I ran some tests to see if I could pinpoint the problem and it is, in fact, an issue with Final Cut Pro. I shot a quick little interview in the studio on our Canon XH-A1, recording in HDV 1080i60 onto a Maxwell miniDV tape.
Test 1:
Captured via Deck: HDV > DV downconvert.
FCP Capture Preset: DV NTSC Anamorphic
Device Control Preset: FireWire NTSC Basic
Output FPS in QT: 29.94Test 2:
Output FPS in QT: 29.94 (seems to be consistent)Test 3:
Captured via Camera: HDV
FCP Capture Preset: HDV
Device Control Preset: HDV FireWire Basic
Output FPS in QT: 29.97Test 4:
Captured via Deck: HDV with no downconvert.
Output FPS in QT: 29.97 (!)Test 5:
Output FPS in QT: 29.97Test 6:
Output FPS in QT: 29.97Test 7:
Output FPS in QT: 29.94Test 8:
Output FPS in QT: 29.94So it seems to be the DV capture preset…. Any thoughts?
Jeremy Garchow
November 25, 2008 at 1:36 am[Michael Cummins] “So it seems to be the DV capture preset…. Any thoughts?”
Yes. Have you tried the fw NTSc or firewire NTSC NDF presets and not the Firewire ‘basic’ preset?
If I remember correctly, firewire basic is not used by the FCP default DV preset.
