Activity › Forums › DaVinci Resolve › DaVinci Resolve 10.1 released
Nedeem Al-astrabadi replied 12 years, 7 months ago 10 Members · 17 Replies
Marc Wielage
January 21, 2014 at 10:34 am[Andrew Shtern] “Map keyboard to Resolve 8 – doesn’t working. It’s now mapping to Resolve 9 shortcuts (kind of). In this mapping Append a Node (Alt-N) shortcut doesn’t working.”
Do what I do and make a little cheat sheet and hang it on the side of your monitor. In a couple of weeks, you’ll figure out the new shortcuts. It’s not rocket science.The other thing you could do is use a shortcut program like QuicKeys to remap the shortcuts yourself. That’s kind of a kludge, but it would work.
Let’s just hope they don’t change them again in Resolve 11…
Francois Driessen
January 22, 2014 at 8:56 pmUPDATE WITH CAUTION!
Working with BMCC DNG – My playback framerate dropped to 5fps vs the 39 I could get on my system before. Reverted back to 10.0.2 All back to normal now.
System: MacPro 3.1 8core 2.6
MacOS 10.9
Quadro 4000 GUI
GTX680 CUDAAnyone else out there with the same issue?
Francois
FireTrigger Inc.
https://firetrigger.com -
Andrew Shtern
January 23, 2014 at 8:19 amYeah, i’ve had similar issue with general performance. Most things are significantly slower, like working with power windows for example (when resizing or moving window it’s stuttering). This version even start about twice longer comparing to 10.0.2.
I’m on MacPro 2012 with 56Gb RAM and Quadro 4000. Rolling back to 10.0.2.Andrew Shtern
Editor/Colorist
The Coffeepost @Kiev, UA -
Margus Voll
January 23, 2014 at 8:33 amQ4000 is by default not wiry powerful ?
Margus
https://iconstudios.eu
https://vimeo.com/iconstudioseu/videosDaVinci 10, OSX 10.8.5
MacPro 5.1 2×2,93 24GB
GUI 4000 / GPU GTX 780
DL 4K
Eizo Color
Scope Box
Full Ligthspace CMS -
Andrew Shtern
January 23, 2014 at 1:20 pmYeah, but that’s not an issue, since 10.0.2 is working way faster, than 10.1
Andrew Shtern
Editor/Colorist
Francois Driessen
January 23, 2014 at 3:03 pmThe first few runs with Resolve was fine after the update. But then after opening & closing Resolve a few times it seriously halted. Similar to an earlier post made by another user above.
Francois
FireTrigger Inc.
Nedeem Al-astrabadi
February 11, 2014 at 1:29 pmThey shouldn’t be changing keyboard shortcuts under a legacy option though, it’s a bizarre decision.
