Activity Forums DaVinci Resolve Davinci Keying without noise
  • Christopher Adams
    July 25, 2012 at 2:47 pm
    One thing you can try is to add a node with higher saturation and key it then after keying reverse the saturation boost. We are using 32bit float here after all.
    I find sometimes it locks on to things better. Also. what kind of footage was it? I find that that will totally effect what you can and can’t key well. Another thing you can try is to do a noise reduction prior in the chain from doing your isolations. Or hell if its a bad clip run it though something like MB-denoiser or my favorite Neat video plugin. Then try keying. I suspect that it will help.
    Just a few ideas. NOTE DLSR footage is some of the worst! to key on. ITs lossy 8bit H.264 breaks down quickly.
    CJ
  • Joseph Mastantuono
    July 25, 2012 at 3:19 pm
    Chris Adams makes a good point.
    DSLR H.264 footage is a main offender. It’s so smushed down that any sort of keying is next to impossible.
    Joseph Mastantuono
    http://www.goodpost.net
    Color Grading & Post Production Consulting
  • Sean Ross
    July 25, 2012 at 7:20 pm
    Thanks Christopher. Good advice.
    I have tried this in other color correctors. I will try it. Although instead of resaturating/desaturating I will do what I do with the noise reduction and split it off as a separate node tree which feed back to the main tree as a matte (or a series of mattes).
    –sean
  • Sean Ross
    July 25, 2012 at 8:12 pm
    I forgot to mention, its Arri Alexa 444 footage.
  • Robert Ruffo
    July 26, 2012 at 1:35 am
    I think curves would likely work better than linear fall-off. It’s easier to change, say, the color of a shirt in the Hue vs curves than in HSL, probably because the falloff is smoother an d easier to control as it uses curves.
    To those who say changing a shirt color, for example, should be VFX and is not part of grading: I say 1998 is over. People expect the color session to be able to affect all things color, and being able to pull clean secondaries is very much part of that.
    I also agree that the sat controls seem almost broken and do not work as expected at all.
    Overall, I would prefer slower but better performance – the expectation of pure 100% realtime is no longer there – tapedeck days are over – it doesn’t really matter. Just give me quality. Maybe give me a “high render” option on the HSL that would be slower but cleaner?
  • Michael Stirling
    July 27, 2012 at 1:12 pm
    You could also try pulling the key in an ‘alpha node’.
    In the key node (3) add loads of saturation and Radius blur and actual Blur.
    In the output node (2) check the invert box in the post mixing part of the key page.
    It just takes the strong key, not the blur or the saturation.
    I agree with comments about the NR – I’ve only ever used it on RED footage successfully. Anything else I use Neat in FCP.
    ~M
  • Joseoscar Sanchez
    January 22, 2018 at 2:45 pm
    Hi sean!
    Just a thing to consider that works for me. I use the 3D qualifier for chroma. But, I do not use the “Despill” option because it introduces a lot of noise to the Key! If I have to supress the spill, I make another node and correct the green or blue spill using the color wheels.
    Hope this works for you!
    God bless!
    Oscar Sánchez
  • Tero Ahlfors
    January 22, 2018 at 8:06 pm
    This is a six year old thread. 3D keyer wasn’t even a thing back then.
  • Joseoscar Sanchez
    January 22, 2018 at 9:06 pm
    Ooops I didn’t noticed… But it is still an issue in version 14! ☺ Try it and you will see.
  • Marc Wielage
    January 23, 2018 at 2:35 am
    The key mixer can help refine chromakeys and stuff like that. There’s some tutorials out there on the web.
Page 3 of 3
