Activity › Forums › DaVinci Resolve › Da Vinci Questions
  • Ryan Walsh
    May 28, 2011 at 9:15 am
    Just an update – I tried trashing the PostgresSQL folder and re-installing Resolve in several configs. I was able to initialize the start scripts via not replacing the postmaster.pid file (leaving the old the one intact) and also only copying over those files/folders which had been modified since original installation.
    The script seems to initialize re-starting itself however after replacing the other data files, DaVinci still does not read the database and reports ‘No Database found’ when opening. I am not sure any extra specific settings to reconnect the database from within DaVinci if I should need to do that.
    How do I copy or replace the database’ data without messing with DaVinci’s file structure hierarchy and accessibility, is there a workable way??
    Thoughts and advice much appreciated!
    RYAN J. WALSH
    edit | design | image
    Flow Creative Inc.
    Sim Video China
    Far Films Asia
    Beijing, P.R. China
    https://ryanwalsh.info
  • Ryan Walsh
    June 3, 2011 at 5:43 pm
    Any updates on this? Was anyone able to advise a way of reconnecting DaVinci to a previous installation’s database files effectively?
    This issue is becoming quite a difficulty as the effort of re-grading my entire RED project at this stage is very daunting. Meanwhile our client is getting more & more impatient!
    Seems there should be some kind of work-around, at least, this system is far from convenient with such issues. Any reason DaVinci couldn’t use a simpler way of saving, and in turn, restoring project files that allows for easier transferal and sharing of user data? The process seems a little too troublesome and time-consuming for any colorist’s liking, no?
    RYAN J. WALSH
    Flow Creative Inc.
    Sim Video China
    Far Films Asia
    Beijing, P.R. China
  • Rohit Gupta
    June 4, 2011 at 2:10 am
    Copying of the “data” directory is generally not a recommended way to moving over postgres databases. The only recommended way is to dump, and restore the database. Or alternatively, if you export individual projects, you can import them into a new database.
    Of course in your case, since the older installation of postgres is no longer running, it is not possible to dump out the database, or export individual projects.
    I suspect you are running into file permission issues, or something like that, but I can’t be sure.
    Here’s a couple of threads I found:
    https://fossplanet.com/f15/%5Bgeneral%5D-moving-postgresql-data-another-computer-35801/
    https://www.postgresql.org/docs/8.4/interactive/backup-file.html
    using google keywords – “postgres moving data directory”
Page 5 of 5
