Cross Platform Export for Broadcast TV usage
Gary Milligan replied 15 years, 9 months ago 4 Members · 11 Replies
Gary Milligan
December 13, 2010 at 5:52 pm[Doug Calhoun] “I’m curious why not export a REF to Compressor or BitVice or can’t BitVice use a REF movie?”
Yes, BitVice can use a REF movie, but in the past I’ve had some unexplained failures such as freeze frames when there shouldn’t be, or just a black movie. There can also be issues with gamma levels changing if there is more than one codec used in the timeline – that can also be a problem when exporting a Self-contained movie, in which case one would need to export as a QuickTime using something other than ‘None” in the compression setting, and then yes, it is re-compressed. Since using either a QuickTime or Self-contained movie in BitVice I’ve never had results with these kinds of problems.
However, I do not consider myself an authority on this – it’s just the way I’ve interpreted and practise the workflow and I reserve the right to be wrong.
Gary
This is me – this is what I do – https://web.mac.com/garymmw
