Activity Forums Adobe After Effects Create a “reflection only” layer
  • Paul Roper
    January 15, 2013 at 9:55 pm
    ….via this link:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Maybe one of the Adobe people (Todd maybe?) will see this thread.
    – Paul
  • Kevin Camp
    January 15, 2013 at 9:56 pm
    sorry… here’s the link
    https://qubahq.com/2010/06/tutorial-100-accurate-reflections/
    i should note that the process for the true reflections is fairly elaborate, involving 2 cameras and precomps, but it does give true reflections for 3d particle systems, and i assume it will work with raytrace 3d.
    i don’t have cs6, but can you precomp the raytraced elements and bring them back into the main comp, and then use blending modes?
    but reflections only would be a worthwhile feature…
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Paul Roper
    January 16, 2013 at 11:14 am
    Thanks for that link I’ll take a look at it later.
    Yes, I thought about doing a pre-comp and bringing it in as a 2D layer with an add or screen mode, but went with the cheating ‘copy & flip the text in the y-axis’ method instead. Not 100% accurate, but did the job.
    – Paul
  • Tim Wilson
    January 24, 2013 at 8:54 pm
    Hey Paul,
    Sorry to bug ya (didn’t mean to bug ya), but can you drop me a line when you get a chance? tim@creativecow.net
    Much appreciated, and apologies again for the interruption…
    Best,
    Tim
    PS. Nothing official. You’re not in trouble. LOL
    Tim Wilson
    Vice President, Editor-in-Chief
    Creative COW
  • Paul Roper
    November 7, 2018 at 11:47 pm
    Well, that’s annoying! I Google “after effects 3d reflection only” and am brought to this thread, where I asked the same question well over 5 years ago! Oh well…maybe I’ll just do the job in C4D.
    motion graphics | VFX | web design | etc.
    https://paulroper.com/
  • Greg Gesch
    November 8, 2018 at 1:02 am
    Hi, don’t know if this would help:
    https://www.videocopilot.net/tutorials/reflection_plug-in/
  • Mark Doctor
    November 8, 2018 at 11:44 pm
    I still have to figure that one out. The empty space around your object is black, unless you use an environmentlayer. By using a green / blue environmentlayer and a color-key, you can isolate the reflection. But it certainly has its limitations
    I never used the double-cam solution. But creating a null object at the position from the floor, link a duplicate from the object to the null and only changing the y-scale from de null to -100%
    But the Environment layer might be a problem that can be solved bij mirroring the horizon. It all depends on what your wishes are
Page 2 of 2
