Activity › Forums › Adobe After Effects › COW Tutorials: After Effects Creating a Cartoon from Video
Aharon Rabinowitz replied 20 years, 5 months ago 6 Members · 12 Replies
Lyon Films
April 5, 2006 at 10:57 pmOK, I did what you suggested by restoring the original file and sure enough, the batch process worked fine. One thing I did note when I was following your instructions, the change I was supposed to make to line 497 was not in the correct spot. I must have changed the wrong line (although it looked correct) and I did heed your advice that there were two lines with that particular text. Not sure what to do…I guess the up side is that I have narrowed the problem down to that one change (the color space change).
Hmmm.
Aharon Rabinowitz
April 5, 2006 at 10:58 pmthe folks at adobe had that same info on a different line, so I guess it’s not exact.
But yeah, make sure to replace the correct instance of that line.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com
