Activity › Forums › Apple Final Cut Pro Legacy › Correct setting for DV in 1920 sequence
Peter Hall replied 14 years, 10 months ago 3 Members · 13 Replies
Rafael Amador
November 17, 2011 at 3:56 pm[Peter Hall] “So you recomend de-interlacing all NTSC DV footage that’s to be viewed on computers?”
Sure.
You may not notice the interlaced combing in YOUR computer, but in others can be really noticeable.
In many small web videos that are uploaded as interlaced, the interlacing is not noticeable because many websites de-interlace on compression.
Also QT doesn’t support interlaced for clips below a certain size (can’t remember the right numbers), so there is always forced a deinterlacing that you can’t control.
Better do it yourself.
There is lot of great stuff in the web (many reels here in The COW) that shows a really annoying interlacing.
rafael
PS: I’ve stop working interlaced long ago to skip all the deinterlacing hassel. -
Peter Hall
November 17, 2011 at 4:17 pmThank you Rafael, I’ve also been shooting progressive but some of that old DV footage desperately needs re-editing, and working with what are now relatively such low res images, I want to give it the best chance. Thank you.
Peter Hall
