Activity › Forums › Apple Final Cut Pro › Copy/Paste from Primary to Secondary – Possible?
Frank Valtellina replied 12 years, 6 months ago 8 Members · 12 Replies
Nick Toth
February 11, 2014 at 6:53 pmTry this
Select clip in project A and shift F to match frame. Switch to project b. Select secondary storyline in project B (click on “shelf” so the secondary storyline is highlighted) and press W to insert clip into secondary storyline at playhead or skimmer position. That way you don’t have to paste as attached and then move it.
anickt
Frank Valtellina
February 13, 2014 at 10:32 amBut If you use shift+F you can’t paste the possible effects you have applied to the clip that you are going to copy
