Activity › Forums › Adobe After Effects Expressions › copy markers from layer markers to comp markers
  • copy markers from layer markers to comp markers
    Posted by Roei Tzoref on July 13, 2016 at 1:10 pm
    hey everybody.
    I have a guide layer with layer markers and I have to manually at every comp set those markers to the comp markers.
    won’t you give a guy a hand?
    Andrei Popa replied 5 years ago 7 Members · 24 Replies
  • 24 Replies
  • Dan Ebberts
    July 13, 2016 at 4:39 pm
    Strangely, scripting doesn’t have direct access to comp markers. This hack should give you comp markers wherever you have markers on a selected layer, but I don’t think there’s any way to copy the comment:
    var theComp = app.project.activeItem;
    var theLayer = theComp.selectedLayers[0];
    var theTimes = [];
    for (var i = 1; i <= theLayer.property("Marker").numKeys; i++){
    theTimes.push(theLayer.property("Marker").keyTime(i));
    for (var i = 1; i <= theComp.numLayers; i++){
    theComp.layer(i).selected = false;
    for (var i = 0; i < theTimes.length; i++){
    theComp.time = theTimes[i];
    app.executeCommand(app.findMenuCommandId("Add Marker"));
    Dan
  • Roei Tzoref
    July 13, 2016 at 7:13 pm
    thank you Dan. at which property, and what composition should I copy this expression too?
  • Dan Ebberts
    July 13, 2016 at 7:21 pm
    It’s a script, not an expression.
    Dan
  • Roei Tzoref
    July 13, 2016 at 7:38 pm
    Got it! it Works! Dan let’s make some money 🙂 this could be very useful at Aescripts. first time I copy pasted a string to the script editor and saved it as a jsx – is that how you started :0
  • Roei Tzoref
    July 13, 2016 at 7:42 pm
    I was thinking of something. is there a way to make this script just add “1”, “2”, “3” etc. to the markers it copies to the comp? just to not leave them blank. that could improve it’s purpose a lot
  • Roei Tzoref
    July 13, 2016 at 7:50 pm
    I am trying to have it close instead of loading that Jsx everytime.
    tried copying it to the scripts folder and restarted Ae and it’s not in File-Scripts.
    copying it to the startup folder in scripts gave an error message when loading Ae.
    is there a way for having it close. of course a docking or a window near by would be great but I am not spoiled. I just want it to be quicker than loading it every time with File->Scripts->Run Script File->clicking on it twice in my Explorer but if that’s all I get I will take it.
    Running Ae 13.8
  • Dan Ebberts
    July 13, 2016 at 7:51 pm
    It would need some work to make it user-proof, run in different languages, etc. I’m not sure there’s any money to be made there.
    Not exactly. In the early days, I’d write the code in Notepad and just save it as a .jsx. Now I usually (unless it’s a really short piece of code, like this one) use the ExtendScript editor, or Sublime Text.
    Dan
  • Dan Ebberts
    July 13, 2016 at 7:55 pm
    I’m not sure what you mean by that.
    Dan
  • Dan Ebberts
    July 13, 2016 at 7:56 pm
    Not that I know of.
    Dan
  • Roei Tzoref
    July 13, 2016 at 8:01 pm
    about the money – I was slightly joking. I would like to make service to the community so I could help if you have an urge to do that. for free and the script could be for free too.
    about loading the script and what I wrote in the previous comment: I want to load the script with as few steps as possible. I tried placing it in Ae Scripts folder and Startup and it’s not making it appear under scripts (file->scripts). am I doing something wrong or it is not possible with the script that you provided?
    now I have 4 steps to make:
    1. click file
    2. go to scripts
    3. run script file
    4. click twice at the script
    anyway to make this shorter?
Page 1 of 3
