Activity Forums Adobe Premiere Pro copy and paste – am I thick or what?!
  • copy and paste – am I thick or what?!
    Posted by Mark Palmos on April 10, 2005 at 6:36 pm
    Hey there,
    I am doing a small job on PP1.5 and have come across a basic problem.
    I cannot seem to be able to mark In and mark Out a section of the timeline, copy it, and paste it elsewhere.
    This is such a basic editing requirement but I have searched the Help files, read the manual, and cannot find out how to do it. All I can manage is to LIFT or EXTRACT, but no way, it seems to PASTE what you have lifted or extracted.
    Please tell me how to do this, I know it is terribly basic, but I cannot figure it out!
    Mark.
    Mark Palmos replied 21 years, 4 months ago 7 Members · 20 Replies
  • 20 Replies
  • Tim Kolb
    April 10, 2005 at 7:31 pm
    You sound like a former *Edit user…
    Unfortunately, the best method would be to click, then shift-click on a group of clips and copy/paste, or simply drag a “marqueeish” box around the clips you need an copy/paste.
    The defining a range with in and out thing isn’t in PPro I’m afraid.
    Sorry.
    TimK
    Kolb Syverson Communications
    Creative Cow Host
    2004, 2005 NAB Post Production Conference Premiere Pro Technical Chair
    Author, “The Easy Guide to Premiere Pro” http://www.focalpress.com
    “Premiere Pro Fast Track DVD Series” http://www.classondemand.net
  • Mark Palmos
    April 10, 2005 at 10:26 pm
    yep, former/current discreet edit user indeed!
    Tim, it is astonishing that pp cannot do that.
    what if I do not want to move all of one clip, but part of one, and a few others and part of the clip at the out point, ie to paste whatever I lifted? I suppose I would then have to split each track and move “clips”. Very strange omission.
    The other thing I was fiddling with and couldnt accomplish was to trim an L cut completely. I could trim it up to the last frame but could not replace the clip completely… there would always be one frame left. So what if I want to trim the audio of one clip right over the audio of the following clip? It seems I cannot do that and have to have one frame of the following clip. Is that true or am I doing something wrong?
    Mark.
  • Craig Howard
    April 10, 2005 at 11:39 pm
    Maybe a solution for you..
    Select clip in timeline – Short cut ‘T'(Match Frame) – set new in and out point in Source Window and insert / overlay drag to new position.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Labrisher
    April 11, 2005 at 5:15 am
    Remember the Program window always shows the frame ahead of the CTI. Thus when you razor at the CTI with the last frame showing in the Program window, you’re razoring the start of the last frame – hence the last frame remains. Move one frame farther (first frame of the following clip shows in Program window) then razor.
    A consequence of this trimming mishap often shows up in a transition when the wayward frame unexpecting appears in the transition. It’s more obvious in some transitions than in others.
  • Mark Palmos
    April 11, 2005 at 7:00 am
    Hi Craig and Labrisher
    The thing is say i want
    XXX|YYY|ZZZ
    xxx yyy zzz
    to become
    XXX|YYY|ZZZ
    xxx xxx xxx
    ie to simply drag the tail of the X clip’s audio over the Y clips audio and then immediately over the z clip’s audio. This would take about a second or less. No matter where or how I split the track (I wouldnt want to split any tracks in this case) there seems to be no way to simply extend X’s audio up till the end of the Z clip WITHOUT having to re-record the clip to the timeline by setting source in and out again, etc… much too tedious a process for a simple and pretty common trimming operation.
    Till later
    Mark.
  • Craig Howard
    April 11, 2005 at 8:36 am
    That would be an “L” edit on x (the audio) track – correct ?
  • Steve Bradbury
    April 11, 2005 at 8:52 am
    If my memory worked better on a Monday morning, or I was sitting in front of a machine that had Premiere on I would be able to confirm whether it is the Ctrl or Alt key that you need to press before adjusting the end of the clip.
  • Mark Palmos
    April 11, 2005 at 9:19 am
    Hello Craig and Steve,
    yes, in my example, the split edit would be on X, and extending the X audio track over both Y and Z. I would expect to do this in two short mouse click-drags since the drag would typically stop at the end of the Y clip and I would have to click and drag it again to trim over the Z audio clip too.
    Now I am not at home, so cannot check it, but from what I remember, Pressing Alt or CTRL you can trim up till but not including the last frame of the Y and Z clips… very very strange anomaly.
    Mark.
  • Labrisher
    April 11, 2005 at 6:16 pm
    Try this:
    1. unlink the video/audio for the three clips
    2. lock the video track
    3. delete audio for yyy and zzz
    4. use Selection tool and drag xxx audio to end of zzz
    5. unlock video track
    6. link video (perhaps first clip) to the extended audio
    Let us know if it works.
  • Tom Scoville
    April 11, 2005 at 7:09 pm
    Steve is correct! Just hold down the ALT key before you grab the tail end of XXX audio to pull it over the other clips. Easy as pie! Now I’m hungry again!
    Tom S
