Activity Forums DVD Authoring Converting NTSC to PAL???
  • Roman Melekh
    January 15, 2010 at 5:46 pm
    for sound speed up/down i use “samplitude studio”
  • Philip Crangle
    January 15, 2010 at 7:23 pm
    hello
    is there a way to do this in sony vegas without using any other programs?
  • Roman Melekh
    January 16, 2010 at 12:22 am
    may be this:
    https://forums.creativecow.net/readpost/24/875940
    In Vegas, you can only get a single speed change (CTRL-Resize the clip) as the velocity envelope only applies to video in Vegas.
  • Philip Crangle
    January 16, 2010 at 11:58 am
    is there a tutorial to do it with the programs you mentinoed in the previous posts?
  • Roman Melekh
    January 16, 2010 at 7:19 pm
    I do not know, I was trained in the studio where I worked 🙂
  • Bouke Vahl
    January 23, 2010 at 5:20 pm
    Michael,
    Not sure if you’re already done, but nevertheless.
    Same question came from a paying client, he wanted to do A LOT of NTSC-Pal conversion for broadcast, and on a VERY low budget.
    I’ve tested Mpeg streamclip, and it can rip DVD content, transcode and convert from NTSC and Pal.
    Experiment with settings (set scaling to HQ, frame blending on, do NOT deinterlace, mind your field dominance, adjust gamma if you need to edit in FCP, toy around and test)
    It looks way better than expected, and it’s for free. (well, you need the MpegII QT playback component if your source is DVD)
    And i’ve only tested on Windows….
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pro’s
Page 2 of 2
