Converting Audio Files to Editable Text
Pavel Popov replied 10 years, 1 month ago 13 Members · 14 Replies
Eunice Lopes
July 9, 2015 at 3:02 pmHi, I’ve read what you said about https://www.speechtotextservice.com but your comment is a bit old. Do you guys still recommend this? I’ve read somewhere that this is amazing but I would like the inside of someone that actually uses the service…
Jason Rock
August 29, 2015 at 2:20 amHi Guys,
Good day to all of you and glad to seeing you all once again. I just want to inform and share to all of you that I’ve recently found a new and innovative Audio and Video transcription service which also provides subtitling and captioning service. They can also do transcription of different languages. The price is cheaper by half the price with what I was using previously as I’ve mentioned above and the turnaround time is much faster!
Check them out guys at https://owltranscription.com/. They’ve just recently launched and their clients are increasing enormously and giving positive feedbacks. If you’re still in need of transcription, I highly recommend you try this.
Hope this helps once more.
Venus Myr
November 15, 2015 at 12:09 amYou can check on this:
https://gotranscript.com/ provides audio to text services, speech to text services, voice to text services, digital audio transcription, MP3 to text. Ensures 99% Transcription Accuracy!
Hope it helps.
Pavel Popov
August 22, 2016 at 3:01 pmYou can use transcription module of Speechpad.pw service. Look at the youtube video of transcribing audio in this module. The service use Google speech API to make the draft of transcription. Then you can use time stamps to edit the draft result.
