Activity › Forums › Adobe After Effects › Convert shape path to mask path
  • Darby Edelen
    September 13, 2007 at 11:28 pm
    [Todd Kopriva] “t sounds like you’re seeing the result of leaving the default fill on the shape. You can turn the fill off or delete it to just see the shape’s stroke. Then, when you animate Trim Paths, you see something more like a write-on effect.”
    You are correct. I guess I was just excited at the prospect of animating text in without having to draw a mask in manually for the Stroke effect. I suppose if I want fills on my text I’ll have to stick to my archaic methods =)
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Todd Kopriva
    September 25, 2007 at 2:29 pm
    Jeff Almasol has posted a script that converts paths on a shape layer to masks.
    Todd Kopriva, technical editor, Adobe Systems Incorporated
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Ben Utzerdame
    March 18, 2010 at 5:00 pm
    But how exactly can I convert a mask path to a shape path?
    If I copy the mask path and paste it onto a shape layer, its a mask for a shape layer. but i want it to be a “normal” path! you know what i mean?
  • Todd Kopriva
    March 18, 2010 at 6:08 pm
    You must select the path property before pasting.
    What do you mean by a “normal” path? A path is either a path for a mask, a path for a shape, a path for a paint stroke…
    Just select the path property that you want to copy; then copy; then select the path property into which you want to paste; then paste.
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
Page 2 of 2
