Activity › Forums › Apple Final Cut Pro Legacy › convert HDV to DVCPROHD w/Powerbook G4 & FCP 5.1.2
Mark Maness replied 19 years, 9 months ago 7 Members · 13 Replies
Mark Maness
November 27, 2006 at 9:34 pm[WideWorld HD] “Right now Im assuming that you need to use some kind of a convertor like the one from Convergent Design to turn the HDV signal into an HDSDI signal first.”
At the moment, this is correct. The ONLY way to capture HDV into DVCProHD is thru a box such as the Convergent Designs converter or the AJA HD10AVA (such as I use).
I use a mixture of HDV and XDCAM HD all of the time but since both are a flavor of Long GOP MPEG, I capture these using DVCProHD and then edit all my material in a DVCProHD sequence.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com -
Sterling Noren
November 27, 2006 at 9:41 pmI have a Kona 2 card. What do I need to do in terms of FCP setups to enable me to capture as DVCPROHD via firewire input?
Sterling Noren
WideWorld HD Productions -
Mark Maness
November 28, 2006 at 4:44 pm[WideWorld HD] “What do I need to do in terms of FCP setups to enable me to capture as DVCPROHD via firewire input?”
Again….
There is NO way for you to capture HDV as DVCProHD thru your firewire port UNLESS you purchase a converter box like the AJA HD10AVA or the Convergent Designs converter.
Please listen to us…. There is NO WAY to capture to DVCProHD thru firewire EXCEPT if you are using a Panasonic DVCProHD deck and DVCProHD recorded tapes.
Once you purchase a converter box, you hook it up to your Kona 2 via the HD-SDI input and select the Easy Setup for DVCProHD 1080i29.97.
Wayne Carey
Schazam Productions
